[MOAB-dev] Make Check Failure
Tim Tautges
tautges at mcs.anl.gov
Tue Aug 30 16:20:11 CDT 2011
What are your configure options?
- tim
On 08/30/2011 03:54 PM, Xiabing Xu wrote:
> I was compiling trunk (5140) with --enable-debug option.
> Error messages:
> Making check in obb
> make[2]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
> make obb_test obb_time obb_tree_tool
> make[3]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
> CXX obb_test.o
> CXXLD obb_test
> CXX obb_time.o
> CXXLD obb_time
> CXX obb_tree_tool.o
> CXXLD obb_tree_tool
> make[3]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
> make check-TESTS
> make[4]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
> FAIL: obb_test
> 1 of 1 test failed
> See test/obb/test-suite.log
> make[4]: *** [test-suite.log] Error 1
> make[4]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
> make[3]: *** [check-TESTS] Error 2
> make[2]: *** [check-am] Error 2
> make[2]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
> make[1]: *** [check-recursive] Error 1
> make[1]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test'
> make: *** [check-recursive] Error 1
> Xiabing
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
