[MOAB-dev] Make Check Failure
Xiabing Xu
xbxu at mcs.anl.gov
Tue Aug 30 15:54:49 CDT 2011
I was compiling trunk (5140) with --enable-debug option.
Error messages:
Making check in obb
make[2]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
make obb_test obb_time obb_tree_tool
make[3]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
CXX obb_test.o
CXXLD obb_test
CXX obb_time.o
CXXLD obb_time
CXX obb_tree_tool.o
CXXLD obb_tree_tool
make[3]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
make check-TESTS
make[4]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
FAIL: obb_test
1 of 1 test failed
See test/obb/test-suite.log
make[4]: *** [test-suite.log] Error 1
make[4]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
make[3]: *** [check-TESTS] Error 2
make[2]: *** [check-am] Error 2
make[2]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test'
make: *** [check-recursive] Error 1
Xiabing
