[MOAB-dev] r5140 - MOAB/trunk/test/parallel
kraftche at cae.wisc.edu
Tue Aug 30 13:14:08 CDT 2011
Author: kraftche
Date: 2011-08-30 13:14:08 -0500 (Tue, 30 Aug 2011)
New Revision: 5140
Modified:
MOAB/trunk/test/parallel/parallel_hdf5_test.cc
Log:
add test to verify that parallel HDF5 write works when some procs have no data
Modified: MOAB/trunk/test/parallel/parallel_hdf5_test.cc
--- MOAB/trunk/test/parallel/parallel_hdf5_test.cc 2011-08-30 18:13:47 UTC (rev 5139)
+++ MOAB/trunk/test/parallel/parallel_hdf5_test.cc 2011-08-30 18:14:08 UTC (rev 5140)
@@ -56,6 +56,7 @@
void test_write_different_element_types();
void test_write_different_tags();
void test_write_polygons();
+void test_write_unbalanced();
const char PARTITION_TAG[] = "PARTITION";
@@ -193,6 +194,8 @@
MPI_Barrier(MPI_COMM_WORLD);
result += RUN_TEST( test_write_polygons );
+ result += RUN_TEST( test_write_unbalanced );
+ MPI_Barrier(MPI_COMM_WORLD);
MPI_Finalize();
@@ -1332,4 +1335,91 @@
+// Some processes have no mesh to write
+ const char file_name[] = "test_write_unbalanced.h5m";
+ int numproc, rank;
+ MPI_Comm_size( MPI_COMM_WORLD, &numproc );
+ MPI_Comm_rank( MPI_COMM_WORLD, &rank );
+ Core moab;
+ Interface &mb = moab;
+ ErrorCode rval;
+ Tag idtag;
+ rval = mb.tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, idtag, MB_TAG_CREAT );
+ CHECK_ERR(rval);
+ // create a shared set
+ const int two = 2;
+ Range entities, sets;
+ EntityHandle set;
+ rval = mb.create_meshset( MESHSET_SET, set );
+ CHECK_ERR(rval);
+ rval = mb.tag_set_data( idtag, &set, 1, &two );
+ CHECK_ERR(rval);
+ sets.insert( set );
