[MOAB-dev] r5121 - in MOAB/trunk: . doc
Tim Tautges
tautges at mcs.anl.gov
Mon Aug 29 15:05:07 CDT 2011
Hmm, this might have less to do with the fact you'd done a make install and more to do with the fact that I moved
ProgOptions.hpp to a new location and maybe that required a 'make clean' to get things right?
- tim
On 08/29/2011 02:57 PM, Iulian Grindeanu wrote:
> Hello,
> It seems that I managed to build tools/mbzoltan/mbpart.
> So, after update, I was still getting those linking errors that I reported before.
> The way I "fixed" it : instead of a "make", I did a "make install" at the root moab folder.
> This triggered a copy of the "updated" moab lib to the right (install) place (the one that contained ProgOptions class).
> Then all the tools were rebuild successfully.
> So I have this more basic question, how is this supposed to work correctly?
> Where was my mistake? Should I have made a distclean? or completely new build? how could I have avoided that linking error?
> So the ProgOptions was moved from tools library to moab library a few commits ago.
> In general, when we do "make" in moab, libraries are build first, then the tools/executables. It seems that initially, my executables were linking against old moab ( not the new one, that contained the ProgOptions).
> When I did "make install", the library was copied before trying to link the new executable (mbpart).
> Any comments?
> Thanks,
> Iulian
>> I still have other errors on mbzoltan (on 32 bit, with mpi, with
>> zoltan)
>> I don't know what is wrong there
>> make[3]: Entering directory
>> `/home/iulian/source/MOABpv/tools/mbzoltan'
>> CXXLD mbpart
>> mbpart.o: In function `main':
>> /home/iulian/source/MOABpv/tools/mbzoltan/mbpart.cpp:43: undefined
>> reference to `ProgOptions::ProgOptions(std::basic_string<char,
>> std::char_traits<char>, std::allocator<char> > const&,
>> std::basic_string<char, std::char_traits<char>, std::allocator<char> >
>> const&)'
>> reference to `ProgOptions::~ProgOptions()'
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
