[MOAB-dev] r5121 - in MOAB/trunk: . doc
Iulian Grindeanu iulian at mcs.anl.gov
Mon Aug 29 14:57:09 CDT 2011
Hello,
It seems that I managed to build tools/mbzoltan/mbpart.
So, after update, I was still getting those linking errors that I reported before.
The way I "fixed" it :  instead of a "make", I did a "make install" at the root moab folder.
This triggered a copy of the "updated" moab lib to the right (install) place (the one that contained ProgOptions class).
Then all the tools were rebuild successfully.
So I have this more basic question, how is this supposed to work correctly?
Where was my mistake? Should I have made a distclean? or completely new build? how could I have avoided that linking error?
So the ProgOptions was moved from tools library to moab library a few commits ago.
In general, when we do "make" in moab, libraries are build first, then the tools/executables. It seems that initially, my executables were linking against old moab ( not the new one, that contained the ProgOptions).
When I did "make install", the library was copied before trying to link the new executable (mbpart).
Any comments?
Iulian
> I still have other errors on mbzoltan (on 32 bit, with mpi, with
> zoltan)
> I don't know what is wrong there
> make[3]: Entering directory
> `/home/iulian/source/MOABpv/tools/mbzoltan'
> CXXLD mbpart
> mbpart.o: In function `main':
> /home/iulian/source/MOABpv/tools/mbzoltan/mbpart.cpp:43: undefined
> reference to `ProgOptions::ProgOptions(std::basic_string<char,
> std::char_traits<char>, std::allocator<char> > const&,
> std::basic_string<char, std::char_traits<char>, std::allocator<char> >
> const&)'
> reference to `ProgOptions::~ProgOptions()'
