[MOAB-dev] [PATCH 2/2] libiGeomMOAB Needs to link libiMesh
Tim Tautges tautges at mcs.anl.gov
Fri Jun 10 12:47:01 CDT 2011
Iulian, am I right in thinking this is in the process of being deprecated by FBengine in MOAB and FBiGeom in MeshKit?
- tim
On 06/10/2011 08:08 AM, Jed Brown wrote:
> On Fri, Jun 10, 2011 at 15:03, Iulian Grindeanu <iulian at mcs.anl.gov
> <mailto:iulian at mcs.anl.gov>> wrote:
>     iGeom in MOAB is built only if you use "--enable-igeom" in configure
>     options.
>     And it is only a partial implementation (it will never be complete :( )
> That's fine, but why install something known to be unlinkable just
> because some functions are missing or might malfunction at run-time? It
> seems to me that the right thing to do is to either
> 1. keep it building and linking, but with failing tests
> 2. remove --with-igeom until it can be linked properly
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
