[MOAB-dev] [PATCH 2/2] libiGeomMOAB Needs to link libiMesh
Iulian Grindeanu
iulian at mcs.anl.gov
Fri Jun 10 12:57:42 CDT 2011
----- Original Message -----
> Iulian, am I right in thinking this is in the process of being
> deprecated by FBengine in MOAB and FBiGeom in MeshKit?
That is one of the many questions I have
FBiGeom is in MeshKit, and iGeom_MOAB offered (a partial) iGeom. FBiGeom offers the (same) partial iGeom.
If we take it out, we cannot easily call iGeom in MOAB
Do we even plan to?
At the same time, if we leave it there, it should be definitely fixed to call FBEngine, but it will be maybe wrong to offer it in 2 places
> - tim
> On 06/10/2011 08:08 AM, Jed Brown wrote:
> > On Fri, Jun 10, 2011 at 15:03, Iulian Grindeanu <iulian at mcs.anl.gov
> > <mailto:iulian at mcs.anl.gov>> wrote:
> > iGeom in MOAB is built only if you use "--enable-igeom" in
> > configure
> > options.
> > And it is only a partial implementation (it will never be
> > complete :( )
> > That's fine, but why install something known to be unlinkable just
> > because some functions are missing or might malfunction at run-time?
> > It
> > seems to me that the right thing to do is to either
> > 1. keep it building and linking, but with failing tests
> > 2. remove --with-igeom until it can be linked properly
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
