[MOAB-dev] [PATCH 2/2] libiGeomMOAB Needs to link libiMesh
    Jed Brown
    jed at 59A2.org
    Fri Jun 10 08:08:59 CDT 2011
On Fri, Jun 10, 2011 at 15:03, Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
> iGeom in MOAB is built only if you use "--enable-igeom" in configure
> options.
> And it is only a partial implementation (it will never be complete :( )
That's fine, but why install something known to be unlinkable just because
some functions are missing or might malfunction at run-time? It seems to me
that the right thing to do is to either
1. keep it building and linking, but with failing tests
2. remove --with-igeom until it can be linked properly
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110610/90064d18/attachment.htm>
