[MOAB-dev] Parallel builds need make clean
Hong-Jun Kim
hongjun at mcs.anl.gov
Tue May 31 13:00:35 CDT 2011
By debugging more, in "Skinner::find_skin_scd" function, "box_dims_tag" seems not defined before skinning.
Hong-Jun
----- Original Message -----
> From: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
> To: "Tim Tautges" <tautges at mcs.anl.gov>
> Cc: moab-dev at mcs.anl.gov
> Sent: Tuesday, May 31, 2011 12:55:44 PM
> Subject: Re: [MOAB-dev] Parallel builds need make clean
> Even after "make clean" or "make distclean", I still have the
> problems.
> In "test_ghost_elements" test of "parallel_unit_tests.cpp",
> "get_expected_ghosts" function returns 0 expected ghosts which is
> wrong.
> It seems "Skinner" has problem to get 2d element skin for structured
> mesh(?) in "resolve_shared_ents" function when mesh file is loaded.
> Skinner looks just get vertex elements instead of getting 2d elements.
> Hong-Jun
> > From: "Tim Tautges" <tautges at mcs.anl.gov>
> > To: moab-dev at mcs.anl.gov
> > Sent: Tuesday, May 31, 2011 12:07:56 PM
> > Subject: [MOAB-dev] Parallel builds need make clean
> > Hi all,
> > I've had a number of people ask about this, so thought I'd send a
> > general note - a recent change is causing existing
> > parallel builds to fail the make check; you'll have to do a 'make
> > clean' then remake, then the checks should run
> > successfully again.
> > - tim
> > "You will keep in perfect peace him whose mind is
> > steadfast, because he trusts in you." Isaiah 26:3
> > Tim Tautges Argonne National Laboratory
> > (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> > phone: (608) 263-8485 1500 Engineering Dr.
> > fax: (608) 263-4499 Madison, WI 53706
