[MOAB-dev] Parallel builds need make clean
Hong-Jun Kim hongjun at mcs.anl.gov
Tue May 31 12:55:44 CDT 2011
Even after "make clean" or "make distclean", I still have the problems.
In "test_ghost_elements" test of "parallel_unit_tests.cpp", "get_expected_ghosts" function returns 0 expected ghosts which is wrong.
It seems "Skinner" has problem to get 2d element skin for structured mesh(?) in "resolve_shared_ents" function when mesh file is loaded.
Skinner looks just get vertex elements instead of getting 2d elements.
Hong-Jun
----- Original Message -----
> From: "Tim Tautges" <tautges at mcs.anl.gov>
> To: moab-dev at mcs.anl.gov
> Sent: Tuesday, May 31, 2011 12:07:56 PM
> Subject: [MOAB-dev] Parallel builds need make clean
> Hi all,
> I've had a number of people ask about this, so thought I'd send a
> general note - a recent change is causing existing
> parallel builds to fail the make check; you'll have to do a 'make
> clean' then remake, then the checks should run
> successfully again.
> - tim
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
