[MOAB-dev] Parallel builds need make clean
    Tim Tautges
    tautges at mcs.anl.gov
    Tue May 31 13:25:15 CDT 2011
Hmm, I haven't seen this.  I'll test now...
- tim
On 05/31/2011 01:00 PM, Hong-Jun Kim wrote:
> By debugging more, in "Skinner::find_skin_scd" function, "box_dims_tag" seems not defined before skinning.
> Hong-Jun
>> From: "Hong-Jun Kim"<hongjun at mcs.anl.gov>
>> To: "Tim Tautges"<tautges at mcs.anl.gov>
>> Cc: moab-dev at mcs.anl.gov
>> Sent: Tuesday, May 31, 2011 12:55:44 PM
>> Subject: Re: [MOAB-dev] Parallel builds need make clean
>> Even after "make clean" or "make distclean", I still have the
>> problems.
>> In "test_ghost_elements" test of "parallel_unit_tests.cpp",
>> "get_expected_ghosts" function returns 0 expected ghosts which is
>> wrong.
>> It seems "Skinner" has problem to get 2d element skin for structured
>> mesh(?) in "resolve_shared_ents" function when mesh file is loaded.
>> Skinner looks just get vertex elements instead of getting 2d elements.
>> Hong-Jun
>>> From: "Tim Tautges"<tautges at mcs.anl.gov>
>>> To: moab-dev at mcs.anl.gov
>>> Sent: Tuesday, May 31, 2011 12:07:56 PM
>>> Subject: [MOAB-dev] Parallel builds need make clean
>>> Hi all,
>>> I've had a number of people ask about this, so thought I'd send a
>>> general note - a recent change is causing existing
>>> parallel builds to fail the make check; you'll have to do a 'make
>>> clean' then remake, then the checks should run
>>> successfully again.
>>> - tim
>>> "You will keep in perfect peace him whose mind is
>>> steadfast, because he trusts in you." Isaiah 26:3
>>> Tim Tautges Argonne National Laboratory
>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>> phone: (608) 263-8485 1500 Engineering Dr.
>>> fax: (608) 263-4499 Madison, WI 53706
