[MOAB-dev] Parallel builds need make clean
Tim Tautges
tautges at mcs.anl.gov
Tue May 31 12:07:56 CDT 2011
Hi all,
I've had a number of people ask about this, so thought I'd send a general note - a recent change is causing existing
parallel builds to fail the make check; you'll have to do a 'make clean' then remake, then the checks should run
successfully again.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
