[MOAB-dev] build question
Iulian Grindeanu
iulian at mcs.anl.gov
Tue May 24 11:08:29 CDT 2011
It is now a static build; I will set the PATH and LD_LIBRARY_PATH to point to the same mpich, and I will let you know
On my laptop (32 bit) works fine too, I am using default mpich from synaptic
I am wondering why the error appears only for cubit-based cgm
----- Original Message -----
> If this is a shared build, then the test file is actually a shell
> script, the actual executable is in the .libs
> directory under that.
> - tim
> On 05/24/2011 10:50 AM, Jason Kraftcheck wrote:
> > On 05/24/2011 10:44 AM, Iulian Grindeanu wrote:
> >> FAIL: partest (exit: 1)
> >> Attempting to use an MPI routine before initializing MPICH
> >> The debugger will not start, and I don't know which one is called
> >> before MPI_Init
> > The debugger will not start? Assuming you figure out what is going
> > on with
> > that, try setting break points in MPI_Comm_rank and MPI_Comm_size.
> > Most
> > codes using MPI call at least one of those before anything else.
> > - jason
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
