[MOAB-dev] build question
Tim Tautges tautges at mcs.anl.gov
Tue May 24 10:56:43 CDT 2011
If this is a shared build, then the test file is actually a shell script, the actual executable is in the .libs
directory under that.
- tim
On 05/24/2011 10:50 AM, Jason Kraftcheck wrote:
> On 05/24/2011 10:44 AM, Iulian Grindeanu wrote:
>> FAIL: partest (exit: 1)
>> Attempting to use an MPI routine before initializing MPICH
>> The debugger will not start, and I don't know which one is called before MPI_Init
> The debugger will not start?  Assuming you figure out what is going on with
> that, try setting break points in MPI_Comm_rank and MPI_Comm_size.  Most
> codes using MPI call at least one of those before anything else.
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
