[MOAB-dev] build question
Tim Tautges
tautges at mcs.anl.gov
Tue May 24 11:14:21 CDT 2011
On 05/24/2011 11:08 AM, Iulian Grindeanu wrote:
> It is now a static build; I will set the PATH and LD_LIBRARY_PATH to point to the same mpich, and I will let you know
> On my laptop (32 bit) works fine too, I am using default mpich from synaptic
On one of your earlier messages you were specifying --with-mpi=/home/fathom/..., I think for MOAB.
> I am wondering why the error appears only for cubit-based cgm
For cubit-based cgm, you'll have at least some shared libs, since that's the only way cubit libs are distributed. Maybe
in your non-cubit cgm you have true static libs.
- tim
>> If this is a shared build, then the test file is actually a shell
>> script, the actual executable is in the .libs
>> directory under that.
>> - tim
>> On 05/24/2011 10:50 AM, Jason Kraftcheck wrote:
>>> On 05/24/2011 10:44 AM, Iulian Grindeanu wrote:
>>>> FAIL: partest (exit: 1)
>>>> Attempting to use an MPI routine before initializing MPICH
>>>> The debugger will not start, and I don't know which one is called
>>>> before MPI_Init
>>> The debugger will not start? Assuming you figure out what is going
>>> on with
>>> that, try setting break points in MPI_Comm_rank and MPI_Comm_size.
>>> Most
>>> codes using MPI call at least one of those before anything else.
>>> - jason
>> "You will keep in perfect peace him whose mind is
>> steadfast, because he trusts in you." Isaiah 26:3
>> Tim Tautges Argonne National Laboratory
>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>> phone: (608) 263-8485 1500 Engineering Dr.
>> fax: (608) 263-4499 Madison, WI 53706
