[MOAB-dev] build question
    Tim Tautges
    tautges at mcs.anl.gov
    Tue May 24 10:15:42 CDT 2011
Is the cgm built --with-mpi?
- tim
On 05/24/2011 10:05 AM, Iulian Grindeanu wrote:
> Hello,
> I still have this error, even for static build (so I do not specify --enable-shared)
> I tried everything, but I cannot make it to work
> It works fine on my laptop, but on mcs account, it does not.
> I am using --with-mpi=/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin
> Rajeev's build is fine, and I even tried going back to cgm version from a month ago
> Again, the error appears only if I am configuring moab with an acis based cgm (cubit 12.2)
> Does anybody have any idea why this would be happening?
> Iulian
>> hello,
>> Does anybody have a moab build with mpi, enable-shared, and with-cgm
>> built with cubit 12.2?
>> I thought I had one, but it was wrong, it was without mpi.
>> The errors are in make check, and all the error messages are about the
>> same:
>> For example, trying to run a test:
>> /MOAB/itaps/imesh>  MOAB_iMeshP_unit_tests
>> Attempting to use an MPI routine before initializing MPICH
>> If I do not build with cgm, all tests pass fine (so, with-mpi,
>> enable-shared).
>> So it seems that there is some conflict between cgm and moab (both are
>> build with mpi, shared), in my configuration.
>> Thanks,
>> Iulian
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
