[MOAB-dev] build question
Iulian Grindeanu iulian at mcs.anl.gov
Tue May 24 10:05:25 CDT 2011
Hello,
I still have this error, even for static build (so I do not specify --enable-shared)
I tried everything, but I cannot make it to work
It works fine on my laptop, but on mcs account, it does not.
I am using --with-mpi=/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin
Rajeev's build is fine, and I even tried going back to cgm version from a month ago
Again, the error appears only if I am configuring moab with an acis based cgm (cubit 12.2)
Does anybody have any idea why this would be happening?
Iulian
----- Original Message -----
> hello,
> Does anybody have a moab build with mpi, enable-shared, and with-cgm
> built with cubit 12.2?
> I thought I had one, but it was wrong, it was without mpi.
> The errors are in make check, and all the error messages are about the
> same:
> For example, trying to run a test:
> /MOAB/itaps/imesh> MOAB_iMeshP_unit_tests
> Attempting to use an MPI routine before initializing MPICH
> If I do not build with cgm, all tests pass fine (so, with-mpi,
> enable-shared).
> So it seems that there is some conflict between cgm and moab (both are
> build with mpi, shared), in my configuration.
> Thanks,
> Iulian
