[MOAB-dev] build question
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Tue May 24 10:38:37 CDT 2011
----- Original Message -----
> Is the cgm built --with-mpi?
> - tim
yes, the same mpi
> >> /MOAB/itaps/imesh> MOAB_iMeshP_unit_tests
> >> Attempting to use an MPI routine before initializing MPICH
> >> If I do not build with cgm, all tests pass fine (so, with-mpi,
> >> enable-shared).
> >> So it seems that there is some conflict between cgm and moab (both
> >> are
> >> build with mpi, shared), in my configuration.
> >> Thanks,
> >> Iulian
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
