[MOAB-dev] r4781 - in MOAB/trunk: itaps/imesh src src/io src/parallel src/parallel/moab tools/refiner
tautges at mcs.anl.gov
Wed Apr 27 19:36:20 CDT 2011
Author: tautges
Date: 2011-04-27 19:36:18 -0500 (Wed, 27 Apr 2011)
New Revision: 4781
Modified:
MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
MOAB/trunk/src/BSPTreePoly.cpp
MOAB/trunk/src/Core.cpp
MOAB/trunk/src/DualTool.cpp
MOAB/trunk/src/Matrix3.hpp
MOAB/trunk/src/io/WriteHDF5.cpp
MOAB/trunk/src/parallel/ParallelMergeMesh.cpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.hpp
MOAB/trunk/src/parallel/moab/ProcConfig.hpp
MOAB/trunk/tools/refiner/RefinerTagManager.cpp
MOAB/trunk/tools/refiner/test_mesh_refiner.cpp
Log:
- remove use of USE_MPI from public API headers, so that MOAB applications
aren't required to define this; in most cases, this won't force any changes
in applications, except for those including ParallelComm.hpp or
ProcConfig.hpp, which will have to be compiled with an mpi-enabled compiler
or with -I options that allow them to resolve mpi.h.
- adding an error check to Interface::load_file, where if a non-NULL entity
set pointer is passed in as the set handle pointer should point to a valid
entity set
- adding various checks for error conditions indicated from a static analysis
of MOAB code from LLNL
- fixed a few bugs in the refiner that were preventing that test from
passing the unit test
Passes make check in parallel and serial.
Modified: MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
--- MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp 2011-04-26 22:45:44 UTC (rev 4780)
+++ MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp 2011-04-28 00:36:18 UTC (rev 4781)
@@ -1464,6 +1464,9 @@
/*out*/ int* status_size, int *err)
// for now, throw an error if lower order entity handles aren't vertices
+ if (iMesh_POINT > new_entity_topology || iMesh_SEPTAHEDRON < new_entity_topology) {
+ ERROR(iBase_INVALID_ARGUMENT, "iMesh_createEntArr: invalid topology.");
EntityType this_type = mb_topology_table[new_entity_topology];
int num_ents = 0, num_verts;
const EntityHandle *lower_ents;
Modified: MOAB/trunk/src/BSPTreePoly.cpp
--- MOAB/trunk/src/BSPTreePoly.cpp 2011-04-26 22:45:44 UTC (rev 4780)
+++ MOAB/trunk/src/BSPTreePoly.cpp 2011-04-28 00:36:18 UTC (rev 4781)
@@ -668,6 +668,7 @@
co_edge = co_edge->nextPtr;
} while (co_edge && co_edge != face->usePtr);
+ if (!edge_ptr) return false;
// Constuct new face and first CoEdge
faceList = new Face( faceList );
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp 2011-04-26 22:45:44 UTC (rev 4780)
+++ MOAB/trunk/src/Core.cpp 2011-04-28 00:36:18 UTC (rev 4781)
@@ -459,6 +459,12 @@
ErrorCode rval;
ReaderIface::IDTag t = { set_tag_name, set_tag_vals, num_set_tag_vals };
ReaderIface::SubsetList sl = { &t, 1, 0, 0 };
+ assert(!file_set || (*file_set && is_valid(*file_set)));
+ if (file_set && !*file_set) {
+ mError->set_last_error( "Non-NULL file set pointer should point to non-NULL set.\n" );
+ return MB_FAILURE;
// if reading in parallel, call a different reader
std::string parallel_opt;
Modified: MOAB/trunk/src/DualTool.cpp
--- MOAB/trunk/src/DualTool.cpp 2011-04-26 22:45:44 UTC (rev 4780)
+++ MOAB/trunk/src/DualTool.cpp 2011-04-28 00:36:18 UTC (rev 4781)
@@ -1946,6 +1946,7 @@
