[MOAB-dev] r4783 - MOAB/trunk/itaps/igeom
iulian at mcs.anl.gov iulian at mcs.anl.gov
Thu Apr 28 12:04:52 CDT 2011
Author: iulian
Date: 2011-04-28 12:04:52 -0500 (Thu, 28 Apr 2011)
New Revision: 4783
Modified:
   MOAB/trunk/itaps/igeom/iGeom.h
   MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
   MOAB/trunk/itaps/igeom/testSmooth.cc
   MOAB/trunk/itaps/igeom/testgeom.cc
Log:
align iGeom.h from MOAB with the one from CGM (r4778)
(note: this is not built by default)
Modified: MOAB/trunk/itaps/igeom/iGeom.h
--- MOAB/trunk/itaps/igeom/iGeom.h	2011-04-28 16:53:43 UTC (rev 4782)
+++ MOAB/trunk/itaps/igeom/iGeom.h	2011-04-28 17:04:52 UTC (rev 4783)
@@ -75,12 +75,10 @@
      * \param instance iGeom instance handle
      * \param descr Pointer to a character string to be filled with a
      *        description of the error from the last iGeom function
-     * \param *err Pointer to error type returned from function
      * \param descr_len Length of the character string pointed to by descr
   void iGeom_getDescription( iGeom_Instance instance,
                              char* descr,
-                             int* err,
                              int descr_len );
     /**\brief  Get the error type returned from the last iGeom function
@@ -89,11 +87,9 @@
      * returned is a member of the iBase_ErrorType enumeration.
      * \param *error_type Error type returned from last iGeom function
   void iGeom_getErrorType( iGeom_Instance instance,
-                           /*out*/ int *error_type,
-                           int *err );
+                           /*out*/ int *error_type );
     /**\brief  Construct a new iGeom instance
Modified: MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
--- MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp	2011-04-28 16:53:43 UTC (rev 4782)
+++ MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp	2011-04-28 17:04:52 UTC (rev 4783)
@@ -226,20 +226,20 @@
    return true;
-void iGeom_getDescription(iGeom_Instance instance, char* descr, int* err,
+void iGeom_getDescription(iGeom_Instance instance, char* descr,
       int descr_len) {
    unsigned int
          len =
                MIN(strlen(iGeom_LAST_ERROR.description), ((unsigned int) descr_len));
    strncpy(descr, iGeom_LAST_ERROR.description, len);
    descr[len] = '\0';
-   RETURN(iBase_SUCCESS);
+   return;
