[MOAB-dev] r4760 - in MOAB/trunk: config itaps/imesh src src/io src/io/mhdf/example src/moab src/parallel test/perf tools tools/dagmc tools/mbcoupler
tautges at mcs.anl.gov
Wed Apr 20 16:41:02 CDT 2011
Author: tautges
Date: 2011-04-20 16:41:01 -0500 (Wed, 20 Apr 2011)
New Revision: 4760
Modified:
MOAB/trunk/config/compiler.m4
MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp
MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
MOAB/trunk/itaps/imesh/partest.cpp
MOAB/trunk/src/BitPage.cpp
MOAB/trunk/src/BitPage.hpp
MOAB/trunk/src/DenseTag.cpp
MOAB/trunk/src/DualTool.cpp
MOAB/trunk/src/FBEngine.cpp
MOAB/trunk/src/Factory.cpp
MOAB/trunk/src/MergeMesh.cpp
MOAB/trunk/src/MeshSet.hpp
MOAB/trunk/src/TagCompare.hpp
MOAB/trunk/src/VarLenSparseTag.cpp
MOAB/trunk/src/VarLenTag.hpp
MOAB/trunk/src/WriteUtil.cpp
MOAB/trunk/src/io/ReadHDF5.cpp
MOAB/trunk/src/io/ReadIDEAS.cpp
MOAB/trunk/src/io/ReadNASTRAN.cpp
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/src/io/ReadNC.hpp
MOAB/trunk/src/io/ReadNCDF.cpp
MOAB/trunk/src/io/ReadSmf.cpp
MOAB/trunk/src/io/ReadSms.cpp
MOAB/trunk/src/io/ReadTetGen.cpp
MOAB/trunk/src/io/Tqdcfr.cpp
MOAB/trunk/src/io/WriteHDF5.cpp
MOAB/trunk/src/io/WriteNCDF.cpp
MOAB/trunk/src/io/WriteSLAC.cpp
MOAB/trunk/src/io/WriteSTL.cpp
MOAB/trunk/src/io/WriteTemplate.cpp
MOAB/trunk/src/io/WriteVtk.cpp
MOAB/trunk/src/io/mhdf/example/info.c
MOAB/trunk/src/io/mhdf/example/validate.c
MOAB/trunk/src/moab/GeomUtil.hpp
MOAB/trunk/src/moab/ScdInterface.hpp
MOAB/trunk/src/parallel/ParallelComm.cpp
MOAB/trunk/src/parallel/ReadParallel.cpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/src/parallel/crystal.c
MOAB/trunk/src/parallel/errmem.c
MOAB/trunk/src/parallel/gs.c
MOAB/trunk/src/parallel/sort_imp.c
MOAB/trunk/src/parallel/transfer.c
MOAB/trunk/test/perf/perf.cpp
MOAB/trunk/test/perf/point_in_elem.cpp
MOAB/trunk/test/perf/seqperf.cpp
MOAB/trunk/tools/ProgOptions.hpp
MOAB/trunk/tools/convert.cpp
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/dagmc_preproc.cpp
MOAB/trunk/tools/dagmc/quads_to_tris_driver.cpp
MOAB/trunk/tools/depth.cpp
MOAB/trunk/tools/gsets.cc
MOAB/trunk/tools/makeops.cpp
MOAB/trunk/tools/mbcoupler/Coupler.cpp
MOAB/trunk/tools/mbmem.cpp
MOAB/trunk/tools/parse.cpp
MOAB/trunk/tools/propagate_tags.cpp
MOAB/trunk/tools/size.cpp
MOAB/trunk/tools/skin.cpp
MOAB/trunk/tools/surfplot.cpp
Log:
Changes to remove lots of warnings produced by Intel compilers.
These changes have been tested with debug/optimized, serial and parallel builds.
But, I still may have missed some platform issues, so I'm crossing my fingers here.
Modified: MOAB/trunk/config/compiler.m4
--- MOAB/trunk/config/compiler.m4 2011-04-20 21:29:37 UTC (rev 4759)
+++ MOAB/trunk/config/compiler.m4 2011-04-20 21:41:01 UTC (rev 4760)
@@ -358,7 +358,7 @@
Intel:*)
FATHOM_CXX_32BIT=-m32
FATHOM_CXX_64BIT=-m64
- FATHOM_CXX_SPECIAL="$EXTRA_INTEL_FLAGS -wd981 -wd383"
+ FATHOM_CXX_SPECIAL="$EXTRA_INTEL_FLAGS -wd981 -wd383 -wd1572 -wd2259"
VisualAge:*)
FATHOM_CXX_32BIT=-q32
@@ -482,7 +482,7 @@
Intel:*)
FATHOM_CC_32BIT=-m32
FATHOM_CC_64BIT=-m64
- FATHOM_CC_SPECIAL="$EXTRA_INTEL_FLAGS -wd981 -wd383"
+ FATHOM_CC_SPECIAL="$EXTRA_INTEL_FLAGS -wd981 -wd383 -wd1572"
GNU:mips*)
FATHOM_CC_32BIT="-mips32 -mabi=32"
Modified: MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp
--- MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp 2011-04-20 21:29:37 UTC (rev 4759)
+++ MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp 2011-04-20 21:41:01 UTC (rev 4760)
@@ -319,30 +319,6 @@
return err;
-static int get_intersection( iMesh_Instance imesh,
- iBase_EntitySetHandle set1,
- iBase_EntitySetHandle set2,
- iBase_EntityType type,
- iMesh_EntityTopology topo,
- std::vector<iBase_EntityHandle>& entities )
- std::vector<iBase_EntityHandle> l1, l2;
- int err;
- err = get_entities( imesh, set1, type, topo, l1 );
- if (err)
- return err;
- err = get_entities( imesh, set2, type, topo, l2 );
- if (err)
- return err;
- std::sort( l1.begin(), l1.end() );
- std::sort( l2.begin(), l2.end() );
- std::set_intersection( l1.begin(), l1.end(),
- l2.begin(), l2.end(),
