[MOAB-dev] r4759 - MOAB/trunk/itaps/imesh
    jvporter at wisc.edu
    Wed Apr 20 16:29:37 CDT 2011
Author: jvporter
Date: 2011-04-20 16:29:37 -0500 (Wed, 20 Apr 2011)
New Revision: 4759
Modified:
   MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
Log:
Don't return an error when removing a tag value from an entity/set that
doesn't have that tag set
Modified: MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
--- MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp	2011-04-20 20:19:49 UTC (rev 4758)
+++ MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp	2011-04-20 21:29:37 UTC (rev 4759)
@@ -1983,8 +1983,11 @@
     EntityHandle set = ENTITY_HANDLE(entity_set_handle);
     ErrorCode result = MOABI->tag_delete_data(TAG_HANDLE(tag_handle), &set, 1);
-      // don't check return; this tag may have never been set on the entity set
-    RETURN(iBase_ERROR_MAP[result]);
+      // don't return an error if the tag simply wasn't set on the ent set
+    if (MB_TAG_NOT_FOUND == result)
+      RETURN(iBase_SUCCESS);
+    else
+      RETURN(iBase_ERROR_MAP[result]);
   void iMesh_setVtxCoord (iMesh_Instance instance,
@@ -2310,8 +2313,11 @@
                                               CONST_HANDLE_ARRAY_PTR(entity_handles),
                                               entity_handles_size);
+      // don't return an error if the tag simply wasn't set on the entities
+    else
   void iMesh_getData (iMesh_Instance instance,
