[MOAB-dev] r4761 - MOAB/trunk/test
iulian at mcs.anl.gov iulian at mcs.anl.gov
Thu Apr 21 08:35:12 CDT 2011
Author: iulian
Date: 2011-04-21 08:35:11 -0500 (Thu, 21 Apr 2011)
New Revision: 4761
Modified:
   MOAB/trunk/test/gttool_test.cpp
Log:
move the creation of shell model here
the output files are deleted by default
Modified: MOAB/trunk/test/gttool_test.cpp
--- MOAB/trunk/test/gttool_test.cpp	2011-04-20 21:41:01 UTC (rev 4760)
+++ MOAB/trunk/test/gttool_test.cpp	2011-04-21 13:35:11 UTC (rev 4761)
@@ -44,9 +44,12 @@
 std::string filename;
 std::string ofile;
+std::string ofile2;
 bool remove_output_file;
 ErrorCode geometrize_test(Interface * mb, EntityHandle inputSet);
+ErrorCode create_shell_test(Interface * mb);
 void handle_error_code(ErrorCode rv, int &number_failed, int &number_successful)
   if (rv == MB_SUCCESS) {
@@ -62,17 +65,20 @@
   filename = TestDir + "/partBed.smf";
   ofile = "output.h5m";
+  ofile2 = "shell.h5m";
   remove_output_file = true;
   if (argc == 1) {
-    std::cout << "Using default input file and output file " << filename << " " << ofile << std::endl;
-  } else if (argc == 3) {
+    std::cout << "Using default input file and output files " << filename << " " << ofile <<
+        " " << ofile2 << std::endl;
+  } else if (argc == 4) {
     filename = argv[1];
     ofile = argv[2];
+    ofile2 = argv[3];
     remove_output_file = false;
   } else {
-    std::cerr << "Usage: " << argv[0] << " [surface_mesh] [mbgeo_file]" << std::endl;
+    std::cerr << "Usage: " << argv[0] << " [surface_mesh] [mbgeo_file] [shellfile]" << std::endl;
     return 1;
@@ -91,6 +97,13 @@
   ErrorCode rval = geometrize_test( mb, 0); // just pass the root set
   handle_error_code(rval, number_tests_failed, number_tests_successful);
   std::cout << "\n";
+  std::cout << "create shell test: ";
+  rval = create_shell_test( mb); // just pass the root set
+  handle_error_code(rval, number_tests_failed, number_tests_successful);
+  std::cout << "\n";
