[MOAB-dev] r4758 - MOAB/trunk/test
iulian at mcs.anl.gov
Wed Apr 20 15:19:49 CDT 2011
Author: iulian
Date: 2011-04-20 15:19:49 -0500 (Wed, 20 Apr 2011)
New Revision: 4758
Modified:
MOAB/trunk/test/Makefile.am
MOAB/trunk/test/gttool_test.cpp
Log:
after all, do not keep the output file of the test, by default.
Modified: MOAB/trunk/test/Makefile.am
--- MOAB/trunk/test/Makefile.am 2011-04-20 17:50:02 UTC (rev 4757)
+++ MOAB/trunk/test/Makefile.am 2011-04-20 20:19:49 UTC (rev 4758)
@@ -56,8 +56,7 @@
tri_mid_edge_face_nodes.g \
mb_stress_out.g \
merge_test.ncdf \
- tree.h5m \
- output.h5m
+ tree.h5m
# Tests and such
Modified: MOAB/trunk/test/gttool_test.cpp
--- MOAB/trunk/test/gttool_test.cpp 2011-04-20 17:50:02 UTC (rev 4757)
+++ MOAB/trunk/test/gttool_test.cpp 2011-04-20 20:19:49 UTC (rev 4758)
@@ -16,6 +16,7 @@
#include <assert.h>
#include <string.h>
+#include <stdio.h>
#include "moab/GeomTopoTool.hpp"
@@ -41,6 +42,9 @@
return MB_FAILURE; // must always return false or CHECK macro will break
+std::string filename;
+std::string ofile;
+bool remove_output_file;
ErrorCode geometrize_test(Interface * mb, EntityHandle inputSet);
void handle_error_code(ErrorCode rv, int &number_failed, int &number_successful)
@@ -56,15 +60,19 @@
int main(int argc, char *argv[])
- std::string filename = TestDir + "/partBed.smf";
- std::string engine_opt;
+ filename = TestDir + "/partBed.smf";
+ ofile = "output.h5m";
+ remove_output_file = true;
if (argc == 1) {
- std::cout << "Using default input file: " << filename << std::endl;
- } else if (argc == 2) {
