[MOAB-dev] A PDE example with MOAB.
Jed Brown jed at 59A2.org
Wed Apr 13 15:43:39 CDT 2011
On Wed, Apr 13, 2011 at 22:15, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> I will definitely look at NEK as per your suggestion but if they only
> use MOAB to read the mesh and convert it to their own mesh data
> structures, it beats the purpose of my question. Thanks for the
> pointer though.
I have a library that does a bit of a hybrid. A key aspect is to retain
enough structure to make high-order and composite finite element methods
efficient while still having reasonable performance for low order. I don't
think it's really what you're looking for because it just pulls out arrays
for most tasks (though it doesn't maintain a full mesh data structure on its
own), but I use sets and tags for some purposes. Be warned that it is quite
immature and since I don't have any users that I know of, I change things
pretty arbitrarily. There are also several places that assume hex elements
rather than work through the correct API. Let me know if you have questions.
https://github.com/jedbrown/dohp
MOAB/iMesh is not user-visible in a typical assembly loop, so Dohp is
probably irrelevant to you
https://github.com/jedbrown/dohp/blob/master/src/fs/tests/ellip.c#L430
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110413/3e01cbb3/attachment.htm>
