[MOAB-dev] Test failure on 4.0 branch with --enable-igeom
Iulian Grindeanu iulian at mcs.anl.gov
Thu Mar 24 22:38:57 CDT 2011
Hello,
I think that this test should really load a geometrized moab file, not an stp or sat file, read through CGM.
(also for testgeom, if there is no cgm, our imesh cannot really load an stp file). testgeom should have failed too
I think that testgeom and testSmoothGeom should both use an h5m file that is "geometrized", i.e., it has the geometry sets, tags, parent-child relations between geometry sets).
The whole point of iGeom in MOAB is interpreting a mesh-based geometry file, when no geometry engine is available, not an stp file. Or maybe we do want to test readCGM, but I think that should be a separate test, not in itaps.
This should be changed on the trunk, not only on the 4.0 branch.
Any comments?
Iulian
----- Original Message -----
> With --enable-geom, I'm getting a segfault in testSmoothGeom. This
> goes back to before I backported any of the ITAPS 1.2 spec changes, so
> this problem has probably been there for a while. This is also one of
> the things that the buildbot doesn't explicitly test (maybe it
> should), since no MOAB build has --enable-igeom.
> - Jim
