[MOAB-dev] Test failure on 4.0 branch with --enable-igeom
Tim Tautges
tautges at mcs.anl.gov
Thu Mar 24 17:12:25 CDT 2011
Iulian?
On 03/24/2011 05:09 PM, James Porter wrote:
> With --enable-geom, I'm getting a segfault in testSmoothGeom. This goes
> back to before I backported any of the ITAPS 1.2 spec changes, so this
> problem has probably been there for a while. This is also one of the
> things that the buildbot doesn't explicitly test (maybe it should),
> since no MOAB build has --enable-igeom.
> - Jim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
