[MOAB-dev] Test failure on 4.0 branch with --enable-igeom
Tim Tautges
tautges at mcs.anl.gov
Fri Mar 25 07:53:22 CDT 2011
I agree with all this.
- tim
On 03/24/2011 10:38 PM, Iulian Grindeanu wrote:
> Hello,
> I think that this test should really load a geometrized moab file, not an stp or sat file, read through CGM.
> (also for testgeom, if there is no cgm, our imesh cannot really load an stp file). testgeom should have failed too
> I think that testgeom and testSmoothGeom should both use an h5m file that is "geometrized", i.e., it has the geometry sets, tags, parent-child relations between geometry sets).
> The whole point of iGeom in MOAB is interpreting a mesh-based geometry file, when no geometry engine is available, not an stp file. Or maybe we do want to test readCGM, but I think that should be a separate test, not in itaps.
> This should be changed on the trunk, not only on the 4.0 branch.
> Any comments?
> Iulian
>> With --enable-geom, I'm getting a segfault in testSmoothGeom. This
>> goes back to before I backported any of the ITAPS 1.2 spec changes, so
>> this problem has probably been there for a while. This is also one of
>> the things that the buildbot doesn't explicitly test (maybe it
>> should), since no MOAB build has --enable-igeom.
>> - Jim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
