[MOAB-dev] Test failure on 4.0 branch with --enable-igeom
James Porter jvporter at wisc.edu
Thu Mar 24 17:09:35 CDT 2011
With --enable-geom, I'm getting a segfault in testSmoothGeom. This goes back to before I backported any of the ITAPS 1.2 spec changes, so this problem has probably been there for a while. This is also one of the things that the buildbot doesn't explicitly test (maybe it should), since no MOAB build has --enable-igeom.
- Jim
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110324/b8cd90e5/attachment.htm>
