[MOAB-dev] r4559 - MOAB/trunk/itaps/imesh
Jason Kraftcheck kraftche at cae.wisc.edu
Wed Mar 9 16:13:47 CST 2011
On 03/09/2011 04:11 PM, Tim Tautges wrote:
> On 03/09/2011 03:43 PM, Jason Kraftcheck wrote:
>> On 03/09/2011 03:34 PM, James Porter wrote:
>>> On Wed, 2011-03-09 at 14:42 -0600, Jason Kraftcheck wrote:
>>>> On 03/09/2011 02:40 PM, James Porter wrote:
>>>>> Should we do the same for iGeom? I have patches for that and iRel
>>>>> ready
>>>>> to go.
>>>> Probably.  But they don't have the same priority as noone else uses or
>>>> implements those interfaces.
>>> So there's one thing still failing here (which is causing failures for
>>> PyTAPS): iMesh_getTagType on a set-type tag returns iBase_ENTITY_HANDLE.
>>> The issue, of course, is that MOAB doesn't need to distinguish between
>>> entities and sets, but ITAPS does. I'm not sure what the best way to fix
>>> this is. Maybe adding a boolean flag to the MOAB tag to distinguish the
>>> two?
>> So what are you proposing?  A new MOAB API to attach some kind of
>> attribute
>> to tags?  Or a special API call just for this flag?
>> I'm not sure that this is worth worrying about.  But if you'd rather
>> change
>> MOAB than your tests then I'd just do something like:
>>    if moab type is HANDLE
>>      get all tagged entities
>>      if range.all_of_type(SET)
>>        return SET_HANDLE
>>      else
>>        return HANDLE
> I think what you want to test is the *values* of those tags, not the
> types of entities they're set on.
Correct. Thanks.
> Also, what happens if/when a tag of
> handle type is set with both entity and entity set handles?
Well, ITAPS doesn't allow that.  If someone does it via MOAB (the MOAB API
(either directly or indirectly via a file), then there isn't much we can do.
- jason
