[MOAB-dev] r4559 - MOAB/trunk/itaps/imesh
    Tim Tautges
    tautges at mcs.anl.gov
    Wed Mar  9 16:17:01 CST 2011
This isn't not only possible, it's likely, given the wide use of GLOBAL_ID.
- tim
On 03/09/2011 04:13 PM, Jason Kraftcheck wrote:
>> Also, what happens if/when a tag of
>> handle type is set with both entity and entity set handles?
> Well, ITAPS doesn't allow that.  If someone does it via MOAB (the MOAB API
> (either directly or indirectly via a file), then there isn't much we can do.
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
