[MOAB-dev] r4559 - MOAB/trunk/itaps/imesh
Tim Tautges
tautges at mcs.anl.gov
Wed Mar 9 16:11:17 CST 2011
On 03/09/2011 03:43 PM, Jason Kraftcheck wrote:
> On 03/09/2011 03:34 PM, James Porter wrote:
>> On Wed, 2011-03-09 at 14:42 -0600, Jason Kraftcheck wrote:
>>> On 03/09/2011 02:40 PM, James Porter wrote:
>>>> Should we do the same for iGeom? I have patches for that and iRel ready
>>>> to go.
>>> Probably. But they don't have the same priority as noone else uses or
>>> implements those interfaces.
>> So there's one thing still failing here (which is causing failures for
>> PyTAPS): iMesh_getTagType on a set-type tag returns iBase_ENTITY_HANDLE.
>> The issue, of course, is that MOAB doesn't need to distinguish between
>> entities and sets, but ITAPS does. I'm not sure what the best way to fix
>> this is. Maybe adding a boolean flag to the MOAB tag to distinguish the
>> two?
> So what are you proposing? A new MOAB API to attach some kind of attribute
> to tags? Or a special API call just for this flag?
> I'm not sure that this is worth worrying about. But if you'd rather change
> MOAB than your tests then I'd just do something like:
> if moab type is HANDLE
> get all tagged entities
> if range.all_of_type(SET)
> return SET_HANDLE
> else
> return HANDLE
I think what you want to test is the *values* of those tags, not the types of entities they're set on. Also, what
happens if/when a tag of handle type is set with both entity and entity set handles?
- tim
> This, of course, won't work if the tag hasn't been set on anything. But it
> will work for file IO. Another alternative is to keep some list of
> set_handle tags in iMesh_MOAB and do the above check on new tags found after
> reading a file or creating with an existing moab::Core.
> - jason
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
