[MOAB-dev] r4559 - MOAB/trunk/itaps/imesh
Tim Tautges tautges at mcs.anl.gov
Wed Mar 9 16:08:35 CST 2011
Another use case for tags on tags...
- tim
On 03/09/2011 03:34 PM, James Porter wrote:
> On Wed, 2011-03-09 at 14:42 -0600, Jason Kraftcheck wrote:
>> On 03/09/2011 02:40 PM, James Porter wrote:
>>> Should we do the same for iGeom? I have patches for that and iRel ready
>>> to go.
>> Probably.  But they don't have the same priority as noone else uses or
>> implements those interfaces.
> So there's one thing still failing here (which is causing failures for
> PyTAPS): iMesh_getTagType on a set-type tag returns iBase_ENTITY_HANDLE.
> The issue, of course, is that MOAB doesn't need to distinguish between
> entities and sets, but ITAPS does. I'm not sure what the best way to fix
> this is. Maybe adding a boolean flag to the MOAB tag to distinguish the
> two?
> This would, unfortunately, require that we serialize that out to files
> to be 100% correct, but that part isn't necessary for the PyTAPS tests
> to pass.
> - Jim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
