[MOAB-dev] r4561 - MOAB/trunk/test
kraftche at cae.wisc.edu
Wed Mar 9 14:18:56 CST 2011
Author: kraftche
Date: 2011-03-09 14:18:56 -0600 (Wed, 09 Mar 2011)
New Revision: 4561
Modified:
MOAB/trunk/test/MBTest.cpp
Log:
fix bug in test code that caused failure if building optimized 32-bit code using g++ 4.4
Modified: MOAB/trunk/test/MBTest.cpp
--- MOAB/trunk/test/MBTest.cpp 2011-03-09 18:02:01 UTC (rev 4560)
+++ MOAB/trunk/test/MBTest.cpp 2011-03-09 20:18:56 UTC (rev 4561)
@@ -810,10 +810,10 @@
return rval;
hex2_faces[0] = hex1_faces[0];
for (int i = 0; i < 5; ++i) {
- rval = mb->create_element( MBQUAD, hex1_face_conn[i], 5, hex1_faces[i+1] );
+ rval = mb->create_element( MBQUAD, hex1_face_conn[i], 4, hex1_faces[i+1] );
if (MB_SUCCESS != rval)
return rval;
- rval = mb->create_element( MBQUAD, hex2_face_conn[i], 5, hex2_faces[i+1] );
+ rval = mb->create_element( MBQUAD, hex2_face_conn[i], 4, hex2_faces[i+1] );
return rval;
@@ -834,7 +834,6 @@
return MB_SUCCESS;
ErrorCode mb_upward_adjacencies_test()
ErrorCode rval;
@@ -844,8 +843,7 @@
// create a simple mesh containing 2 hexes
EntityHandle vertices[12], hexes[2], hex1_faces[6], hex2_faces[6], hex1_edges[12], hex2_edges[12];
rval = create_two_hex_full_mesh( mb, vertices, hexes, hex1_faces, hex2_faces, hex1_edges, hex2_edges );
- if (MB_SUCCESS != rval)
- return rval;
+ CHKERR(rval);
// test adjacences from dim to 3
for (int dim = 0; dim < 3; ++dim) {
@@ -855,11 +853,9 @@
switch (dim) {
case 0:
rval = mb->get_connectivity( hexes[0], list1, n );
- return rval;
+ CHKERR(rval);
rval = mb->get_connectivity( hexes[1], list2, n );
- return rval;
+ CHKERR(rval);
break;
case 1:
list1 = hex1_edges;
@@ -872,6 +868,8 @@
n = 6;
