[MOAB-dev] r4559 - MOAB/trunk/itaps/imesh
Tim Tautges
tautges at mcs.anl.gov
Wed Mar 9 16:29:23 CST 2011
That's what I get for answering emails while listening to other stuff at a meeting...
- tim
On 03/09/2011 04:18 PM, Jason Kraftcheck wrote:
> On 03/09/2011 04:17 PM, Tim Tautges wrote:
>> This isn't not only possible, it's likely, given the wide use of GLOBAL_ID.
> GLOBAL_ID is an integer tag, not a handle tag.
> - jason
>> - tim
>> On 03/09/2011 04:13 PM, Jason Kraftcheck wrote:
>>>> Also, what happens if/when a tag of
>>>> handle type is set with both entity and entity set handles?
>>> Well, ITAPS doesn't allow that. If someone does it via MOAB (the MOAB
>>> API
>>> (either directly or indirectly via a file), then there isn't much we
>>> can do.
>>> - jason
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
