[MOAB-dev] r4559 - MOAB/trunk/itaps/imesh
Jason Kraftcheck
kraftche at cae.wisc.edu
Wed Mar 9 15:58:01 CST 2011
On 03/09/2011 03:06 PM, James Porter wrote:
> On Wed, 2011-03-09 at 14:42 -0600, Jason Kraftcheck wrote:
>> On 03/09/2011 02:40 PM, James Porter wrote:
>>> Should we do the same for iGeom? I have patches for that and iRel ready
>>> to go.
>> Probably. But they don't have the same priority as noone else uses or
>> implements those interfaces.
> Should we also update iBase.h to be in sync with ITAPS? There are a
> couple of annoying things with this:
> 1) The TagValueType enum's order was changed so there are probably ABI
> compatibility issues (esp with CGM, which I think just saves/loads
> the integer value of the type).
Well that was an annoying surprise. I've fixed that much.
> 2) We need to be able to distinguish between a tag whose data type is
> "entity" and a tag whose data type is "set". MOAB obviously doesn't
> care about this distinction, but ITAPS does.
See other message.
- jason
