[MOAB-dev] naming conventions?
Jiangtao Hu
jiangtao_ma at yahoo.com
Mon Feb 14 11:51:41 CST 2011
Hi, Iulian
If my understanding is correct, you are using mesh/facet data to create linear/smooth geometry of surfaces and curves. After this, are you providing query functions for properties of those geometries, and if possible, allowing any modification of those geometries? If you are at least providing or going to provide query of the geometry that you created, these functions should be integrated to CGM/geom/facet directory.
At least CGM facet needs these mesh-to-geometry functions too.
Jane
--- On Mon, 2/14/11, Hong-Jun Kim <hongjun at mcs.anl.gov> wrote:
Subject: Re: [MOAB-dev] naming conventions?
To: moab-dev at mcs.anl.gov
Date: Monday, February 14, 2011, 10:33 AM
I hope it has all information in the name as "mbfacetgeom" not confused by others or future tools.
Hong-Jun
----- Original Message -----
> From: "Iulian Grindeanu" <iulian at mcs.anl.gov>
> To: "Tim Tautges" <tautges at mcs.anl.gov>
> Cc: moab-dev at mcs.anl.gov
> Sent: Monday, February 14, 2011 9:04:20 AM
> Subject: [MOAB-dev] naming conventions?
> Hello,
> I would like to commit a new tool to moab, one for mesh-based
> geometry.
> What should be a good name?
> Right now, the tool is called mbfacet, but this name could be confused
> with faceting in CGM. It is, in a way, an inverse process, mesh
> populated with right sets and tags is interpreted as geometry (linear
> or smooth). The main class is called FBEngine (Facet Based Engine),
> which will implement a lot of iGeom-like methods.
> I was thinking also mbgeom (for mesh based geometry), but mb usually
> stands for moab :(
> Does anybody have better suggestions?
> Thanks,
> Iulian
____________________________________________________________________________________
Bored stiff? Loosen up...
Download and play hundreds of games for free on Yahoo! Games.
http://games.yahoo.com/games/front
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110214/096b18d4/attachment.htm>
