[MOAB-dev] r4478 - MOAB/trunk/itaps/igeom
iulian at mcs.anl.gov
Mon Jan 31 15:34:51 CST 2011
Author: iulian
Date: 2011-01-31 15:34:50 -0600 (Mon, 31 Jan 2011)
New Revision: 4478
Modified:
MOAB/trunk/itaps/igeom/iGeom.h
MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
MOAB/trunk/itaps/igeom/iGeom_MOAB.hpp
Log:
Change the iGeom.h file to be the one from CGM/itaps folder.
One of the changes is that "iGeom_EntityIterator"s are replaced with
iBase_EntityIterator's
Some other changes in iGeom.h are not clear. Need to investigate more, to see
why there are different iGeom.h files in our 2 different implementations of
iGeom
Modified: MOAB/trunk/itaps/igeom/iGeom.h
--- MOAB/trunk/itaps/igeom/iGeom.h 2011-01-31 18:17:23 UTC (rev 4477)
+++ MOAB/trunk/itaps/igeom/iGeom.h 2011-01-31 21:34:50 UTC (rev 4478)
@@ -1,3283 +1,3789 @@
-#ifndef _ITAPS_iGeom
-#define _ITAPS_iGeom
- /** \mainpage The ITAPS Geometry Interface iGeom
- * The ITAPS Geometry Interface iGeom provides a common interface for
- * accessing geometry and data associated with a mesh. Applications written
- * to use this interface can use a variety of implementations, choosing
- * the one that best meets its needs. They can also use tools written
- * to this interface.
- * \section ITAPS Data Model
- * The ITAPS interfaces use a data model composed of four basic data types:\n
- * \em Entity: basic topological entities in a model, e.g. vertices,
- * edges, faces, regions. \n
- * \em Entity \em Set: arbitrary grouping of other entities and sets.
- * Entity sets also support parent/child relations with other sets which
- * are distinct from entities contained in those sets. Parent/child links
- * can be used to embed graph relationships between sets, e.g. to
- * represent topological relationships between the sets. \n
- * \em Interface: the object with which model is associated and on which
- * functions in iGeom are called. \n
- * \em Tag: application data associated with objects of any of the other
- * data types. Each tag has a designated name, size, and data type.
- * \section JTAPS Entity Type
- * Each entity has a specific Entity Type. The Entity
- * Type is one of VERTEX, EDGE, FACE, and REGION, and is synonymous with
- * the topological dimension of the entity. Entity Type is an enumerated
- * type in the iBase_EntityType enumeration.
- * \section KTAPS Entity-, Array-, and Iterator-Based Access
- * The iGeom interface provides functions for accessing entities
- * individually, as arrays of entities, or using iterators. These access
- * methods have different memory versus execution time tradeoffs,
- * depending on the implementation.
- * \section LTAPS Lists Passed Through Interface
- * Many of the functions in iGeom have arguments corresponding to lists of
- * objects. In-type arguments for lists consist of a pointer to an array and
- * a list size. Lists returned from functions are passed in three arguments,
- * a pointer to the array representing the list, and pointers to the
- * allocated and occupied lengths of the array. These three arguments are
