[MOAB-dev] buildbot failure in Fathom on moab-par
moab-dev at mcs.anl.gov moab-dev at mcs.anl.gov
Mon Jan 31 00:09:49 CST 2011
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/408
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
test_read : success
test_read : success
PASS: uber_parallel_test
PASS: scdtest
Warning: acis file has sequence numbers!
PASS: pcomm_serial
Running test_write_elements ...
Running test_write_shared_sets ...
Running test_var_length_parallel ...
Running test_read_elements ...
Running test_read_elements_by_rank ...
Running test_read_tags ...
Running test_read_global_tags ...
Running test_read_sets ...
PASS: parallel_hdf5_test
PASS: mhdf_parallel
Using default interval count: 2
01:   0.02: Generating mesh
00:   0.01: Generating mesh
00:   0.13: Resolving shared entities
01:   0.14: Resolving shared entities
00:   0.45: Beginning parallel write
01:   0.46: Beginning parallel write
Wrote 16 hexes in 0.09 seconds.
01:   0.55: Finalizing MPI
00:   0.54: Removing written file
00:   0.54: Finalizing MPI
Wall time: generate: 0.122282, resovle shared: 0.32155, write_file: 0.106157
PASS: parallel_write_test
1 of 8 tests failed
sincerely,
 -The Fathomatic
