[MOAB-dev] r4482 - in MOAB/trunk: src src/moab src/parallel src/parallel/moab test/parallel
tautges at mcs.anl.gov
Thu Feb 3 14:46:08 CST 2011
Author: tautges
Date: 2011-02-03 14:46:08 -0600 (Thu, 03 Feb 2011)
New Revision: 4482
Modified:
MOAB/trunk/src/MergeMesh.cpp
MOAB/trunk/src/moab/MergeMesh.hpp
MOAB/trunk/src/parallel/ParallelMergeMesh.cpp
MOAB/trunk/src/parallel/moab/ParallelMergeMesh.hpp
MOAB/trunk/test/parallel/parmerge.cpp
Log:
A few changes to merging after working with Nathan.
Modified: MOAB/trunk/src/MergeMesh.cpp
--- MOAB/trunk/src/MergeMesh.cpp 2011-02-03 19:19:48 UTC (rev 4481)
+++ MOAB/trunk/src/MergeMesh.cpp 2011-02-03 20:46:08 UTC (rev 4482)
@@ -13,21 +13,19 @@
namespace moab {
-moab::ErrorCode MergeMesh::merge_entities(moab::EntityHandle *elems,
- int elems_size,
- const double merge_tol,
- const int do_merge,
- const int update_sets,
- moab::Tag merge_tag)
+ moab::ErrorCode MergeMesh::merge_entities(moab::EntityHandle *elems,
+ int elems_size,
+ const double merge_tol,
+ const int do_merge,
+ const int update_sets,
+ moab::Tag merge_tag)
mergeTol = merge_tol;
mergeTolSq = merge_tol*merge_tol;
moab::Range tmp_elems;
- tmp_elems.insert(elems, elems + elems_size);
- moab::ErrorCode result = merge_entities(tmp_elems, do_merge, update_sets,
+ tmp_elems.insert( elems, elems + elems_size);
+ moab::ErrorCode result = merge_entities(tmp_elems, merge_tol, do_merge, update_sets,
(moab::Tag)merge_tag);
return result;
@@ -42,10 +40,14 @@
moab::ErrorCode MergeMesh::merge_entities(moab::Range &elems,
+ mergeTol = merge_tol;
+ mergeTolSq = merge_tol*merge_tol;
// get the skin of the entities
moab::Skinner skinner(mbImpl);
