[MOAB-dev] buildbot failure in Fathom on moab-32bit
moab-dev at mcs.anl.gov
Wed Jan 12 00:28:09 CST 2011
The Fathomatic has detected a failed build of moab-32bit on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/moab-32bit/builds/350
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
entity_connectivity_test: Success
vertex_coordinates_test: Success
topology_dimension_test: Success
entity_sets_test: Success
vertex_tag_test: Success
entityset_tag_test: Success
mesh_tag_test: Success
set_remove_contained_regression: Success
all_adjacency_regression: Success
error_code_test: Success
ordered_set_regression: Success
array_allocation_regression: Success
TSTT TEST SUMMARY:
Number Tests: 14
Number Successful: 14
Number Not Implemented: 0
Number Failed: 0
PASS: testc_cbind
Running test_getEntArrAdj_conn ...
Running test_getEntArrAdj_vertex ...
Running test_getEntArrAdj_up ...
Running test_getEntArrAdj_down ...
Running test_getEntArrAdj_invalid_size ...
Running test_getEntArrAdj_none ...
Running test_existinterface ...
test_existinterface: TERMINATED (signal 11)
7 tests registered
7 tests selected
6 of 7 tests passed
1 of 7 tests FAILED
FAIL: MOAB_iMesh_unit_tests
1 of 2 tests failed
sincerely,
-The Fathomatic
