[MOAB-dev] buildbot failure in Fathom on moab-distcheck
    moab-dev at mcs.anl.gov
    Wed Jan 12 00:51:52 CST 2011
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/378
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
./MOAB_iMesh_unit_tests[0x408220]
/lib/libc.so.6(__libc_start_main+0xf4)[0x2b03ae9f21c4]
./MOAB_iMesh_unit_tests(__gxx_personality_v0+0x1c1)[0x4077d9]
======= Memory map: ========
00400000-00583000 r-xp 00000000 09:00 7226620                            /disk/itaps-buildslave/moab-distcheck/build/moab-4.99/_build/itaps/imesh/MOAB_iMesh_unit_tests
00783000-00785000 rw-p 00183000 09:00 7226620                            /disk/itaps-buildslave/moab-distcheck/build/moab-4.99/_build/itaps/imesh/MOAB_iMesh_unit_tests
00785000-007f0000 rw-p 00785000 00:00 0                                  [heap]
2b03ad601000-2b03ad61e000 r-xp 00000000 08:01 685786                     /lib/ld-2.7.so
2b03ad61e000-2b03ad684000 rw-p 2b03ad61e000 00:00 0
2b03ad81e000-2b03ad820000 rw-p 0001d000 08:01 685786                     /lib/ld-2.7.so
2b03ad820000-2b03ad854000 r-xp 00000000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b03ad854000-2b03ada54000 ---p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b03ada54000-2b03ada55000 rw-p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b03ada55000-2b03ada57000 rw-p 2b03ada55000 00:00 0
2b03ada57000-2b03adbef000 r-xp 00000000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2b03adbef000-2b03addee000 ---p 00198000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2b03addee000-2b03addf8000 rw-p 00197000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2b03addf8000-2b03ade05000 rw-p 2b03addf8000 00:00 0
2b03ade05000-2b03ade1b000 r-xp 00000000 08:01 326575                     /lib/libpthread-2.7.so
2b03ade1b000-2b03ae01b000 ---p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2b03ae01b000-2b03ae01d000 rw-p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2b03ae01d000-2b03ae022000 rw-p 2b03ae01d000 00:00 0
2b03ae022000-2b03ae038000 r-xp 00000000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b03ae038000-2b03ae238000 ---p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b03ae238000-2b03ae239000 rw-p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b03ae239000-2b03ae328000 r-xp 00000000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b03ae328000-2b03ae528000 ---p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b03ae528000-2b03ae52e000 r--p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b03ae52e000-2b03ae531000 rw-p 000f5000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b03ae531000-2b03ae544000 rw-p 2b03ae531000 00:00 0
2b03ae544000-2b03ae5c4000 r-xp 00000000 08:01 326565                     /lib/libm-2.7.so
2b03ae5c4000-2b03ae7c3000 ---p 00080000 08:01 326565                     /lib/libm-2.7.so
2b03ae7c3000-2b03ae7c5000 rw-p 0007f000 08:01 326565                     /lib/libm-2.7.so
2b03ae7c5000-2b03ae7c6000 rw-p 2b03ae7c5000 00:00 0
2b03ae7c6000-2b03ae7d3000 r-xp 00000000 08:01 692969                     /lib/libgcc_s.so.1
2b03ae7d3000-2b03ae9d3000 ---p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2b03ae9d3000-2b03ae9d4000 rw-p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2b03ae9d4000-2b03aeb2c000 r-xp 00000000 08:01 685789                     /lib/libc-2.7.so
2b03aeb2c000-2b03aed2c000 ---p 00158000 08:01 685789                     /lib/libc-2.7.so
2b03aed2c000-2b03aed2f000 r--p 00158000 08:01 685789                     /lib/libc-2.7.so
2b03aed2f000-2b03aed31000 rw-p 0015b000 08:01 685789                     /lib/libc-2.7.so
2b03aed31000-2b03aed36000 rw-p 2b03aed31000 00:00 0
2b03aed36000-2b03aed3e000 r-xp 00000000 08:01 326577                     /lib/librt-2.7.so
2b03aed3e000-2b03aef3d000 ---p 00008000 08:01 326577                     /lib/librt-2.7.so
2b03aef3d000-2b03aef3f000 rw-p 00007000 08:01 326577                     /lib/librt-2.7.so
2b03aef3f000-2b03aef41000 rw-p 2b03aef3f000 00:00 0  test_existinterface: TERMINATED (signal 6)
 7 tests registered
 7 tests selected
 6 of  7 tests passed
 1 of  7 tests FAILED
sincerely,
 -The Fathomatic
