[MOAB-dev] buildbot failure in Fathom on moab-par
    moab-dev at mcs.anl.gov
    Wed Jan 12 00:24:39 CST 2011
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/389
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
/lib/libc.so.6(__libc_start_main+0xf4)[0x2b9eb8c301c4]
./MOAB_iMesh_unit_tests(__gxx_personality_v0+0x261)[0x407ad9]
======= Memory map: ========
00400000-008f9000 r-xp 00000000 09:00 7358702                            /disk/itaps-buildslave/moab-par/build/itaps/imesh/MOAB_iMesh_unit_tests
00af8000-00aff000 rw-p 004f8000 09:00 7358702                            /disk/itaps-buildslave/moab-par/build/itaps/imesh/MOAB_iMesh_unit_tests
00aff000-00b8c000 rw-p 00aff000 00:00 0                                  [heap]
2b9eb79e4000-2b9eb7a01000 r-xp 00000000 08:01 685786                     /lib/ld-2.7.so
2b9eb7a01000-2b9eb7a04000 rw-p 2b9eb7a01000 00:00 0
2b9eb7c01000-2b9eb7c03000 rw-p 0001d000 08:01 685786                     /lib/ld-2.7.so
2b9eb7c03000-2b9eb7c37000 r-xp 00000000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b9eb7c37000-2b9eb7e37000 ---p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b9eb7e37000-2b9eb7e38000 rw-p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b9eb7e38000-2b9eb7e3a000 rw-p 2b9eb7e38000 00:00 0
2b9eb7e3a000-2b9eb7e50000 r-xp 00000000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b9eb7e50000-2b9eb8050000 ---p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b9eb8050000-2b9eb8051000 rw-p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b9eb8051000-2b9eb8067000 r-xp 00000000 08:01 326575                     /lib/libpthread-2.7.so
2b9eb8067000-2b9eb8267000 ---p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2b9eb8267000-2b9eb8269000 rw-p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2b9eb8269000-2b9eb826e000 rw-p 2b9eb8269000 00:00 0
2b9eb826e000-2b9eb8276000 r-xp 00000000 08:01 326577                     /lib/librt-2.7.so
2b9eb8276000-2b9eb8475000 ---p 00008000 08:01 326577                     /lib/librt-2.7.so
2b9eb8475000-2b9eb8477000 rw-p 00007000 08:01 326577                     /lib/librt-2.7.so
2b9eb8477000-2b9eb8566000 r-xp 00000000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b9eb8566000-2b9eb8766000 ---p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b9eb8766000-2b9eb876c000 r--p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b9eb876c000-2b9eb876f000 rw-p 000f5000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b9eb876f000-2b9eb8782000 rw-p 2b9eb876f000 00:00 0
2b9eb8782000-2b9eb8802000 r-xp 00000000 08:01 326565                     /lib/libm-2.7.so
2b9eb8802000-2b9eb8a01000 ---p 00080000 08:01 326565                     /lib/libm-2.7.so
2b9eb8a01000-2b9eb8a03000 rw-p 0007f000 08:01 326565                     /lib/libm-2.7.so
2b9eb8a03000-2b9eb8a04000 rw-p 2b9eb8a03000 00:00 0
2b9eb8a04000-2b9eb8a11000 r-xp 00000000 08:01 692969                     /lib/libgcc_s.so.1
2b9eb8a11000-2b9eb8c11000 ---p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2b9eb8c11000-2b9eb8c12000 rw-p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2b9eb8c12000-2b9eb8d6a000 r-xp 00000000 08:01 685789                     /lib/libc-2.7.so
2b9eb8d6a000-2b9eb8f6a000 ---p 00158000 08:01 685789                     /lib/libc-2.7.so
2b9eb8f6a000-2b9eb8f6d000 r--p 00158000 08:01 685789                     /lib/libc-2.7.so
2b9eb8f6d000-2b9eb8f6f000 rw-p 0015b000 08:01 685789                     /lib/libc-2.7.so
2b9eb8f6f000-2b9eb97d9000 rw-p 2b9eb8f6f000 00:00 0
2b9ebc000000-2b9ebc021000 rw-p 2b9ebc000000 00:00 0
2b9ebc021000-2b9ec0000000 ---p 2b9ebc021000 00:00 0
7fff117bd000-7fff117d2000 rw-p 7ffffffe9000 00:00 0                      [stack]
7fff117fe000-7fff11800000 r-xp 7fff117fe000 00:00 0                      [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
  test_existinterface: TERMINATED (signal 6)
 7 tests registered
 7 tests selected
 6 of  7 tests passed
 1 of  7 tests FAILED
sincerely,
 -The Fathomatic
