[MOAB-dev] buildbot failure in Fathom on moab-serial
    moab-dev at mcs.anl.gov
    Wed Jan 12 00:23:34 CST 2011
The Fathomatic has detected a failed build of moab-serial on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-serial/builds/385
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
./MOAB_iMesh_unit_tests[0x407de4]
./MOAB_iMesh_unit_tests[0x408220]
/lib/libc.so.6(__libc_start_main+0xf4)[0x2b871bec31c4]
./MOAB_iMesh_unit_tests(__gxx_personality_v0+0x1c1)[0x4077d9]
======= Memory map: ========
00400000-00583000 r-xp 00000000 09:00 7506849                            /disk/itaps-buildslave/moab-serial/build/itaps/imesh/MOAB_iMesh_unit_tests
00783000-00785000 rw-p 00183000 09:00 7506849                            /disk/itaps-buildslave/moab-serial/build/itaps/imesh/MOAB_iMesh_unit_tests
00785000-007f0000 rw-p 00785000 00:00 0                                  [heap]
2b871aad2000-2b871aaef000 r-xp 00000000 08:01 685786                     /lib/ld-2.7.so
2b871aaef000-2b871ab55000 rw-p 2b871aaef000 00:00 0
2b871acef000-2b871acf1000 rw-p 0001d000 08:01 685786                     /lib/ld-2.7.so
2b871acf1000-2b871ad25000 r-xp 00000000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b871ad25000-2b871af25000 ---p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b871af25000-2b871af26000 rw-p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b871af26000-2b871af28000 rw-p 2b871af26000 00:00 0
2b871af28000-2b871b0c0000 r-xp 00000000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2b871b0c0000-2b871b2bf000 ---p 00198000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2b871b2bf000-2b871b2c9000 rw-p 00197000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2b871b2c9000-2b871b2d6000 rw-p 2b871b2c9000 00:00 0
2b871b2d6000-2b871b2ec000 r-xp 00000000 08:01 326575                     /lib/libpthread-2.7.so
2b871b2ec000-2b871b4ec000 ---p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2b871b4ec000-2b871b4ee000 rw-p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2b871b4ee000-2b871b4f3000 rw-p 2b871b4ee000 00:00 0
2b871b4f3000-2b871b509000 r-xp 00000000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b871b509000-2b871b709000 ---p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b871b709000-2b871b70a000 rw-p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b871b70a000-2b871b7f9000 r-xp 00000000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b871b7f9000-2b871b9f9000 ---p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b871b9f9000-2b871b9ff000 r--p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b871b9ff000-2b871ba02000 rw-p 000f5000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b871ba02000-2b871ba15000 rw-p 2b871ba02000 00:00 0
2b871ba15000-2b871ba95000 r-xp 00000000 08:01 326565                     /lib/libm-2.7.so
2b871ba95000-2b871bc94000 ---p 00080000 08:01 326565                     /lib/libm-2.7.so
2b871bc94000-2b871bc96000 rw-p 0007f000 08:01 326565                     /lib/libm-2.7.so
2b871bc96000-2b871bc97000 rw-p 2b871bc96000 00:00 0
2b871bc97000-2b871bca4000 r-xp 00000000 08:01 692969                     /lib/libgcc_s.so.1
2b871bca4000-2b871bea4000 ---p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2b871bea4000-2b871bea5000 rw-p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2b871bea5000-2b871bffd000 r-xp 00000000 08:01 685789                     /lib/libc-2.7.so
2b871bffd000-2b871c1fd000 ---p 00158000 08:01 685789                     /lib/libc-2.7.so
2b871c1fd000-2b871c200000 r--p 00158000 08:01 685789                     /lib/libc-2.7.so
2b871c200000-2b871c202000 rw-p 0015b000 08:01 685789                     /lib/libc-2.7.so
2b871c202000-2b871c207000 rw-p 2b871c202000 00:00 0
2b871c207000-2b871c20f000 r-xp 00000000 08:01 326577                     /lib/librt-2.7.so
2b871c20f000-2b871c40e000 ---p 00008000 08:01 326577                     /lib/librt-2.7.so
2b871c40e000-2b871c410000 rw-p 00007000 08:01 326577                     /l  test_existinterface: TERMINATED (signal 6)
 7 tests registered
 7 tests selected
 6 of  7 tests passed
 1 of  7 tests FAILED
sincerely,
 -The Fathomatic
