[MOAB-dev] r4368 - in MOAB/trunk: . config src/io src/parallel test/parallel
tautges at mcs.anl.gov
Tue Dec 14 09:22:03 CST 2010
Author: tautges
Date: 2010-12-14 09:22:03 -0600 (Tue, 14 Dec 2010)
New Revision: 4368
Modified:
MOAB/trunk/config/ccmio.m4
MOAB/trunk/config/compiler.m4
MOAB/trunk/config/netcdf.m4
MOAB/trunk/configure.ac
MOAB/trunk/src/io/Makefile.am
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/src/io/ReadNC.hpp
MOAB/trunk/src/parallel/ReadParallel.cpp
MOAB/trunk/test/parallel/Makefile.am
Log:
ReadParallel.cpp: automatically create the partition tag if none is input
ReadNC: enable support for pnetcdf and parallel reading
configure.ac, config/netcdf.m4: change default to not look for netcdf unless requested with --with-netcdf; also
enable looking for pnetcdf
ccmio.m4: change default so it really doesn't look for ccmio
compiler.m4: add --with-mpi= to DISTCHECK_CONFIGURE_FLAGS if it was input
test/parallel/Makefile.am: add some temp files to the list
Passes make distcheck.
Modified: MOAB/trunk/config/ccmio.m4
--- MOAB/trunk/config/ccmio.m4 2010-12-13 22:49:00 UTC (rev 4367)
+++ MOAB/trunk/config/ccmio.m4 2010-12-14 15:22:03 UTC (rev 4368)
@@ -24,7 +24,7 @@
# if CCMIO support is not disabled
HAVE_CCMIO=no
-if test "xno" != "x$CCMIO_ARG"; then
+if test "xyes" = "x$CCMIO_ARG"; then
HAVE_CCMIO=yes
# if a path is specified, update LIBS and INCLUDES accordingly
Modified: MOAB/trunk/config/compiler.m4
--- MOAB/trunk/config/compiler.m4 2010-12-13 22:49:00 UTC (rev 4367)
+++ MOAB/trunk/config/compiler.m4 2010-12-14 15:22:03 UTC (rev 4368)
@@ -83,6 +83,7 @@
CXX_LIST="mpiCC mpCC mpicxx"
FC_LIST="mpif90"
F77_LIST="mpif77"
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-mpi=\"${withval}\""
if test "xyes" == "x$WITH_MPI"; then
FATHOM_SET_MPI_COMPILER([CC], [$CC_LIST])
Modified: MOAB/trunk/config/netcdf.m4
--- MOAB/trunk/config/netcdf.m4 2010-12-13 22:49:00 UTC (rev 4367)
+++ MOAB/trunk/config/netcdf.m4 2010-12-14 15:22:03 UTC (rev 4368)
@@ -28,10 +28,10 @@
DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-netcdf=\"${withval}\""
, [NETCDF_ARG=])
-if test "xno" = "x$NETCDF_ARG"; then
+if test "xyes" = "x$NETCDF_ARG"; then
+ AC_MSG_RESULT([yes])
+else
AC_MSG_RESULT([no])
-else
- AC_MSG_RESULT([yes])
fi
# if NetCDF support is not disabled
@@ -141,3 +141,128 @@
fi
]) # FATHOM_HAVE_NETCDF
+AC_DEFUN([FATHOM_CHECK_PNETCDF],[
