[MOAB-dev] r4367 - MOAB/trunk/src
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Mon Dec 13 16:49:00 CST 2010
Author: kraftche
Date: 2010-12-13 16:49:00 -0600 (Mon, 13 Dec 2010)
New Revision: 4367
Modified:
   MOAB/trunk/src/TagCompare.hpp
Log:
fix build issue on surveyor
Modified: MOAB/trunk/src/TagCompare.hpp
--- MOAB/trunk/src/TagCompare.hpp	2010-12-13 21:54:07 UTC (rev 4366)
+++ MOAB/trunk/src/TagCompare.hpp	2010-12-13 22:49:00 UTC (rev 4367)
@@ -266,13 +266,13 @@
     case MB_TYPE_INTEGER:
       switch (tag_info.get_size()) {
         case MB_VARIABLE_LENGTH:
-          find_tag_values( TagVarIntsEqual( value, size ), begin, end, results );
+          find_tag_values<TagVarIntsEqual,IteratorType>( TagVarIntsEqual( value, size ), begin, end, results );
           break;
         case sizeof(int):
-          find_tag_values( TagOneIntEqual( value ), begin, end, results );
+          find_tag_values<TagOneIntEqual,IteratorType>( TagOneIntEqual( value ), begin, end, results );
           break;
         default:
-          find_tag_values( TagIntsEqual( value, size ), begin, end, results );
+          find_tag_values<TagIntsEqual,IteratorType>( TagIntsEqual( value, size ), begin, end, results );
           break;
       break;
@@ -280,13 +280,13 @@
     case MB_TYPE_DOUBLE:
-          find_tag_values( TagVarDoublesEqual( value, size ), begin, end, results );
+          find_tag_values<TagVarDoublesEqual,IteratorType>( TagVarDoublesEqual( value, size ), begin, end, results );
           break;
         case sizeof(double):
-          find_tag_values( TagOneDoubleEqual( value ), begin, end, results );
+          find_tag_values<TagOneDoubleEqual,IteratorType>( TagOneDoubleEqual( value ), begin, end, results );
           break;
         default:
-          find_tag_values( TagDoublesEqual( value, size ), begin, end, results );
+          find_tag_values<TagDoublesEqual,IteratorType>( TagDoublesEqual( value, size ), begin, end, results );
           break;
       break;
@@ -294,22 +294,22 @@
     case MB_TYPE_HANDLE:
-          find_tag_values( TagVarHandlesEqual( value, size ), begin, end, results );
+          find_tag_values<TagVarHandlesEqual,IteratorType>( TagVarHandlesEqual( value, size ), begin, end, results );
           break;
         case sizeof(EntityHandle):
-          find_tag_values( TagOneHandleEqual( value ), begin, end, results );
+          find_tag_values<TagOneHandleEqual,IteratorType>( TagOneHandleEqual( value ), begin, end, results );
           break;
         default:
-          find_tag_values( TagHandlesEqual( value, size ), begin, end, results );
