[MOAB-dev] r4347 - in MOAB/trunk/src: . io moab
tautges at mcs.anl.gov
Thu Dec 9 22:34:20 CST 2010
Author: tautges
Date: 2010-12-09 22:34:20 -0600 (Thu, 09 Dec 2010)
New Revision: 4347
Modified:
MOAB/trunk/src/Range.cpp
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/src/io/ReadNCDF.cpp
MOAB/trunk/src/io/ReadNCDF.hpp
MOAB/trunk/src/moab/Range.hpp
Log:
Range: changed implementation of psize to be inlined, and removed my redundant num_sub_ranges function (thanks Jason)
ReadNCDF: changed to use C interface
Passes make check.
Modified: MOAB/trunk/src/Range.cpp
--- MOAB/trunk/src/Range.cpp 2010-12-09 20:35:02 UTC (rev 4346)
+++ MOAB/trunk/src/Range.cpp 2010-12-10 04:34:20 UTC (rev 4347)
@@ -70,20 +70,6 @@
return size;
- returns the number of pairs in the list
-EntityHandle Range::psize() const
- // go through each pair and add up the number of values
- // we have.
- EntityHandle size=0;
- for(PairNode* iter = mHead.mNext; iter != &mHead; iter = iter->mNext)
- ++size;
- return size;
advance iterator
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2010-12-09 20:35:02 UTC (rev 4346)
+++ MOAB/trunk/src/io/ReadNC.cpp 2010-12-10 04:34:20 UTC (rev 4347)
@@ -344,7 +344,7 @@
rval = mbImpl->get_entities_by_dimension(file_set, 0, verts);
ERRORR(rval, "Trouble getting vertices in set.");
assert("Should only have a single vertex subrange, since they were read in one shot" &&
- verts.num_sub_ranges() == 1);
+ verts.psize() == 1);
// get ptr to tag space
Range::iterator viter = verts.begin();
Modified: MOAB/trunk/src/io/ReadNCDF.cpp
--- MOAB/trunk/src/io/ReadNCDF.cpp 2010-12-09 20:35:02 UTC (rev 4346)
+++ MOAB/trunk/src/io/ReadNCDF.cpp 2010-12-10 04:34:20 UTC (rev 4347)
@@ -18,7 +18,7 @@
#endif
#include "ReadNCDF.hpp"
-#include "netcdf.hh"
+#include "netcdf.h"
