[MOAB-dev] r4348 - in MOAB/trunk/src: io moab
tautges at mcs.anl.gov
Fri Dec 10 11:02:55 CST 2010
Author: tautges
Date: 2010-12-10 11:02:55 -0600 (Fri, 10 Dec 2010)
New Revision: 4348
Modified:
MOAB/trunk/src/io/ReadNCDF.cpp
MOAB/trunk/src/io/WriteNCDF.cpp
MOAB/trunk/src/io/WriteNCDF.hpp
MOAB/trunk/src/moab/Range.hpp
Log:
- made Range::psize return size_t instead of unsigned int
- converted WriteNCDF to use netcdf C interface
Passes make check
Modified: MOAB/trunk/src/io/ReadNCDF.cpp
--- MOAB/trunk/src/io/ReadNCDF.cpp 2010-12-10 04:34:20 UTC (rev 4347)
+++ MOAB/trunk/src/io/ReadNCDF.cpp 2010-12-10 17:02:55 UTC (rev 4348)
@@ -435,14 +435,14 @@
GET_DIM(temp_dim, "len_line", max_line_length);
// title; why are we even bothering if we're not going to keep it???
- char *title = new char[max_line_length+1];
fail = nc_inq_att(ncFile, NC_GLOBAL, "title", &att_type, &att_len);
if (NC_NOERR != fail) {
readMeshIface->report_error("ReadNCDF:: Problem getting title attribute.");
return MB_FAILURE;
- if (att_type != NC_CHAR || (int)att_len > max_line_length) {
- readMeshIface->report_error("ReadNCDF:: title didn't have type char or was too long.");
+ char *title = new char[att_len+1];
+ if (att_type != NC_CHAR) {
+ readMeshIface->report_error("ReadNCDF:: title didn't have type char.");
return MB_FAILURE;
fail = nc_get_att_text(ncFile, NC_GLOBAL, "title", title);
@@ -707,6 +707,7 @@
readMeshIface->report_error("ReadNCDF:: Problem getting connectivity.");
return MB_FAILURE;
// Convert from exodus indices to vertex handles.
// Iterate backwards in case handles are larger than ints.
for (int i = number_nodes - 1; i >= 0; --i)
Modified: MOAB/trunk/src/io/WriteNCDF.cpp
--- MOAB/trunk/src/io/WriteNCDF.cpp 2010-12-10 04:34:20 UTC (rev 4347)
+++ MOAB/trunk/src/io/WriteNCDF.cpp 2010-12-10 17:02:55 UTC (rev 4348)
@@ -28,6 +28,7 @@
#include "WriteNCDF.hpp"
+#include "netcdf.h"
#include <utility>
#include <algorithm>
#include <time.h>
@@ -53,6 +54,34 @@
#define INS_ID(stringvar, prefix, id) \
sprintf(stringvar, prefix, id)
+#define GET_DIM(ncdim, name, val)\
+ int fail = nc_inq_dimid(ncFile, name, &ncdim); \
+ if (NC_NOERR == fail) { \
