[MOAB-dev] r4346 - in MOAB/trunk: . config
    kraftche at cae.wisc.edu
    Thu Dec  9 14:35:02 CST 2010
Author: kraftche
Date: 2010-12-09 14:35:02 -0600 (Thu, 09 Dec 2010)
New Revision: 4346
Modified:
   MOAB/trunk/config/compiler.m4
   MOAB/trunk/configure.ac
Log:
Don't pass -pedantic to Intel compiler
Modified: MOAB/trunk/config/compiler.m4
--- MOAB/trunk/config/compiler.m4	2010-12-09 20:25:08 UTC (rev 4345)
+++ MOAB/trunk/config/compiler.m4	2010-12-09 20:35:02 UTC (rev 4346)
@@ -341,7 +341,7 @@
   Intel:*)
     FATHOM_CXX_32BIT=-m32
     FATHOM_CXX_64BIT=-m64
-    FATHOM_CXX_SPECIAL="$EXTRA_GNU_FLAGS -wd981 -wd383"
+    FATHOM_CXX_SPECIAL="$EXTRA_INTEL_FLAGS -wd981 -wd383"
   VisualAge:*)
     FATHOM_CXX_32BIT=-q32
@@ -465,7 +465,7 @@
   Intel:*)
     FATHOM_CC_32BIT=-m32
     FATHOM_CC_64BIT=-m64
-    FATHOM_CC_SPECIAL="$EXTRA_GNU_FLAGS -wd981 -wd383"
+    FATHOM_CC_SPECIAL="$EXTRA_INTEL_FLAGS -wd981 -wd383"
   GNU:mips*)
     FATHOM_CC_32BIT="-mips32 -mabi=32"
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac	2010-12-09 20:25:08 UTC (rev 4345)
+++ MOAB/trunk/configure.ac	2010-12-09 20:35:02 UTC (rev 4346)
@@ -22,6 +22,7 @@
   [ENABLE_FORTRAN=$enableval],[ENABLE_FORTRAN=yes])
 EXTRA_GNU_FLAGS='-Wall -pipe -pedantic -Wno-long-long'
+EXTRA_INTEL_FLAGS='-Wall'
 FATHOM_CHECK_COMPILERS([yes],[yes],[$ENABLE_FORTRAN])
 AM_CONDITIONAL(PARALLEL,[test "x$WITH_MPI" != "xno"])
 LIBS="-lm"
