[MOAB-dev] Changing the options format in iMesh
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Nov 15 12:30:39 CST 2010
On 11/15/2010 12:18 PM, Jason Kraftcheck wrote:
> On 11/15/2010 12:13 PM, James Porter wrote:
>> In order to be compatible with the iMesh spec, we need to change the
>> options format. Currently, it seems that MOAB uses the old iMesh-defined
>> options syntax. Should we continue to support this syntax, or should
>> MOAB use the new iMesh syntax? (Or maybe MOAB should have its own
>> syntax?)
> MOAB already has its own syntax and I don't see any advantage to changing it.
>> For reference, the new way is "impl1:opt1 impl2:opt2", e.g. "moab:silent
>> moab:foobar". If MOAB got its own syntax instead of just doing this, I'd
>> expect the options to look like "silent foobar" by the time it got to
>> MOAB.
> That should actually be "; silent foobar" when passed to MOAB.
Wait, I thought with MOAB the starting delimiter was optional... and if they're two separate options, I'd expect
"silent;foobar", no?
- tim
>> Options for other implementations would be stripped at the iMesh
>> level.
> This seems like the obvious place to do so, as there are many iMesh
> implementations but only one MOAB implementation.  An implementation prefix
> at the MOAB level wouldn't make sense.
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
